Api.box.com SSL Certificate issue HTTP ERROR 401
It appeared that since end of last week, our API calls from server to api.box.com has been failing. On further investigation opening https://api.box.com using browser, there appeared to be issues with the site certificate itself. and browser returned HTTP ERROR 401.
Hello :raised_hand:,
It looks like someone has created a support ticket for you all about this issue already! Support should be able to get this solved for you.
Thanks,
Alex, Box Developer Advocate :avocado:
