Box CLI Commands Options (Fields and Extra Fields)
Hi,
When I use the metadata-query command and try to add more options to query more data about the file creation date using the Fields option or the Extra-Fields option, no results show up, only file name and file id
Here is the command box metadata-query enterprise_******.department 1736501103 --fields=created_at
----- File 1342427526557 -----
Type: file
Also need to know the list of options that I can use under Fields and Extra-Fields as the Box CLI is not showing any help or examples for it.
Thanks
Welcome to the forum @user711 :slight_smile:
I think that created_at is an extra-field, not a field.
Can you try the following :
box metadata-query enterprise_******.department 1736501103  --extra-fields type,id,created_at
I would recommend you to use this documentation :
You’ll find many examples.
