Box CLI Events not showing results
Hi,
I am trying to use the following Box CLI to get my enterprise event but it doesn’t show any data, the cursor keeps blink as fi the CMD has frozen, not results or reports generated.
box events --enterprise --created-after 2024-04-28
Appreciate your help
Hi @user711
Thanks for using BoxCLI, please make sure that the user making the API call will need to have admin privileges, and the application will need to have the scope manage enterprise properties checked.
To further investigate, can you providing the Authentication method you are using? (JWT, CCG), try to use --verbose flag to see the debug information and try with smaller / bigger date range?
If it’s not working, I suggest to create an issue on BoxCLI repo, so the team will check it carefully.
Best regards,
Minh
