Box storage-policies:assignments:lookup $ManagedUserID Failed
Hello,
I’m working through creating my first application. I have my script working to create new users using the CLI. I am working on using the command for storage policies.
When I run the command:
box storage-policies:assignments:lookup $ManagedUserID
I get “box : Unexpected API Response [404 Not Found | 04b98908e769f2e0] not_found - Authorization Failed”
I’m sure this is due to some sort of permissions, but I’m not sure why.
I created the application using Client Credentials Grant.
I have given every permission except for “Generate user access tokens”.
So far in my script I have not had to generate a token.
To assign a storage policy do I have to use a token?
Thank you.
