Developer tokens not generating after request for approval
Do developer tokens cease working after a request for application approval? Every time I try to generate a token it seems to work but the token gives me a expiration error and if I refresh the developer console the developer token does not persist. My application is not approved yet and so I’m now blocked. I can’t find anything in the docs.
Thanks in advance for your help!
This seems to have been an intermittent issue that has now worked itself out. Hopefully it stays fixed.
Hi @RamseyAustin
Glad it got sorted out, but nevertheless welcome to the forum.
Feel free to post thoughts, comments and questions, we’re here to share.
BTW, a developer token can be annoying since it has to be manually generated every 60 minutes.
Let us know when you’re ready to explore other forms of authentication.
On a separate note, I’m wondering if you are or work from Austin Texas, we will be doing a developer day on Feb 7th, in Austin…
Here are the details in case you’re interested:
Box Platform Developer Day — Austin
Cheers
