Error parsing PKCS private key for Box Developer Edition
While creating new app in enterprise account, getting “Error parsing PKCS private key for Box Developer Edition.”. Using box sdk 2.58.0.
Hi @ritika , welcome to the forum.
Can you elaborate a bit more? Perhaps share a code sample?
Box platform does not store your private key.
Assuming you’re talking about a JSON Web Token configured application, and are trying to get an access token, it seems your application is having trouble reading or parsing the private key.
If this is the case how did you generate the private/public keys?
If you used the box developer console, then the private key is encrypted it self, check if the passphrase is correct.
Let us know
Cheers
