How many refresh tokens can be obtained simultaneously per client ID for Box?
Hi!
I have a question about Box’s OAuth2.
For instance, GOOGLE allows up to 100 refresh tokens to be obtained for one Client ID.
There is currently a limit of 100 refresh tokens per Google Account per OAuth 2.0 client ID. If the limit is reached, creating a new refresh token automatically invalidates the oldest refresh token without warning. This limit does not apply to service accounts
Hi @Yun , welcome to the forum!!!
Interesting question, per client id I don’t think there is a limit.
However per client id and user id the limit is 1.
This means a refresh token can only be used once, and you get a new refresh token for that user and client id.
To avoid concurrency issues if the same refresh token is used more than one time during a certain time period your app gets the same new access and refresh token.
I don’t remember exactly how long the period is but consider it to be seconds.
Let us know if this helps.
Cheers
