How to save errors from bulk CLI command
Kindly I need to know how to save errors report coming from CLI bulk command to identify which entries that didn’t succeed
How I can save these entries?
Entry 130 (
id=351859192851
template-key=recordRetentionClassificationCreationDateTrigger
data=retentionCode=PMDS-007 | Clinical Manufacturing and Distribution
as-user=3875303392
) failed with error:
Unexpected API Response [400 Bad Request | 2papqzhh552766yi.0906f287fbb26895fb5fe968f7ebe8bbf] bad_request - Request contains invalid parameters.
Entry 131 (
id=351859035675
as-user=3875303392
Unexpected API Response [400 Bad Request | ea3opchh5527i4t7.014cfae7169598b3ae2af37e3bb7afeb1] bad_request - Request contains invalid parameters.
Hi @user711 :slight_smile:
I’m not sure how to export error messages, but for example, if you need to export a User list into a CSV file, you would need to run something like this :
box users --csv --save-to-file-path=//Users/XXX/Downloads/export.csv
Of course, you need to replace the path with the path of your machine.
Thanks, unfortunately this didn’t work out, the whole point that I am executing a bulk command that has thousands of entries so i need to review the errors which are more than CMD can buffer
