Is there a way i can derive enterprise id from access token?
I wanted to derive enterprise id from access token. For example, in salesforce we can derive orgid from access token.
Hi
There is nothing directly in the access token that will let you derive the enterprise ID. I think your best bet is to use the users/me endpoint
https://api.box.com/2.0/users/me?fields=enterprise should return something like
    "type": "user",
    "id": "13110169300",
    "enterprise": {
        "type": "enterprise",
        "id": "57767591",
        "name": "Peter's Demo Account"
