Is there a way to get the authorization immediately instead of waiting for 15 - 20 days
We are trying to access the file name using the box api. To do that we are using OAuth authentication. But we authorization is pending and we reached out to Admin contact still waiting for the reply.
Can someone pls suggest best way to integrate box with our application to read the file name which is in Box. Please do the needful
Thanks in Advance.
Hello :raised_hand:,
This process will be done by the admin of your Box instance at your company/in your IT department. They will follow the process described here. Unfortunately, we at Box cannot speed that process up.
Thanks,
Alex, Box Developer Advocate :avocado:
