Issue on clearCache method on Content Explorer Widget?
As per Box documentation, the clearCache function of Content Explorer should force reload the items. But when I call the same function, I don’t see any reload of items in Content Explorer widget.
I am using Content Explorer version 17.1.0.
  • Clears out the internal in-memory
  • cache for the content explorer forcing
  • re-load of items via the API.
  • @public
  • @return {void}
    contentExplorer.clearCache();
Any errors on the console?
There are no errors on the console.
Hey @Niladri!
I can see where there’s confusion with that comment. The clearCache() method won’t actually immediately re-load the items, it just means the next time a network request should be made, it will not use any cached result.
You can see the implementation of the method here:
Hi @tjuanitas,
It’s great to have a better understanding of how the “clearCache” method operates, thanks to your explanation.
