Marker-Based Pagination w/ PythonSDK
Hello community,
Is there a way to use the Marker-Based Pagination with Python SDK? I’m currently trying to perform a search that will exceed the 10.000 limitation for the ‘offset’ property. Therefore, I’m trying to perform it with a marker-based object collection but haven’t found any documentation on how to perform the search with Python scripting.
I would really appreciate your help upon this matter.
Thanks in advance!
Hi,
thanks for reaching us. Unfortunately marker based pagination is not supported for search endpoint. Please take a look at the guide: https://developer.box.com/guides/search/pagination/.
Best,
Lukasz
Hi Isocha,
Thanks for the qucik reply. Is there any other way in which I could use marker-based pagination with Python SDK?
Yes,
for the endpoints that support marker-based pagination, corresponding methods usually have use_marker flag, which can enable maker-based pagination for you. Example: box-python-sdk/boxsdk/object/folder.py at 5a7c767deea0c0cafb6997d2d96819b724cd8a59 · box/box-python-sdk · GitHub.
Best,
Lukasz
