N8n - no code platform integration errors
Hello!
Has anyone used the no code platform n8n to create workflows? I am currently working on an image tagging workflow that would trigger when a folder is created in a specified box location, and then send those images to be tagged and then update the metadata being stored in a json file.
When I create actions in the workflow like get files or get folders, I have no issues. But when I use a box trigger node to start the workflow, I get the following error message :
Forbidden - perhaps check your credentials?
Show Details
Box Trigger: 403 - “”
