My public key is not found on my configuration page please advise
Hi @Jimmy
Can you elaborate on your question?
What type of key are you looking for?
Is it an API Key? Developer token perhaps?
These are usually found under the developer console, for a specific app.
Try navigating to the developer console
For some reason it’s not showing on my developers app
Im trying to connect my box account to my bubble account
Hi @Jimmy, thanks for posting your question. Can you please provide a detailed description of your use case? Some additional information about the configuration you’re trying to achieve would be helpful to analyse the problem you’re facing.
In order to get enterprise ID do I need a pay account
