Rust client for Box Platform released
Following up with the Rusty Box: Creating a Rust client for a hackathon, we have released a crate with an initial implementation of the users API end points.
You can find the crate here.
You can follow up and participate in this open source project at this GitHub repo.
If you want to try it:
Create a new rust project
cargo new my-box-project
cd my-box-project
Add rusty-box to your dependencies
cargo add dotenv
cargo add rusty-box
Create a .dev.env file in the root of your project
DEVELOPER_TOKEN=YOUR_DEVELOPER_TOKEN
Open your main.rs file and add the following code
use rusty_box::{
    auth::{auth_developer::DeveloperToken, AuthError},
    box_client::BoxClient,
    config::Config,
    rest_api::users::users_api,
use std::env;
#[tokio::main]
async fn main() -> Result<(), AuthError> {
    dotenv::from_filename(".dev.env").ok();
    let config = Config::new();
    let auth = DeveloperToken::new(
        config,
        env::var("DEVELOPER_TOKEN").expect("DEVELOPER_TOKEN must be set"),
    let mut client = BoxClient::new(Box::new(auth.clone()));
    let fields = vec![];
    let me = users_api::me(&mut client, Some(fields)).await?;
    println!("Me:\n{me:#?}\n");
    Ok(())
Run your project
cargo run
Have fun!
