[First post – please bear with me.]
Box recently sent me a notice about deprecating some SSL protocols.
Legacy SSL Ciphers Deprecation
The suggestion is to use “api-test(.)box(.)com” instead of the normal “api(.)box(.)com” to test whether you need to make security changes to your app. The problem I’m facing is I use the BOX SDK v.2 (with C#) which has “api(.)box(.)com” hardcoded in the library so I can’t change it to use the testing URL.
[The (.) is to get around the new user 1 link only restrictions.]
Any suggestions? Please let me know if you need more info.
thanks,
randy
Hey there, welcome to the forum!
I’m not familiar with the C# SDK, so I can’t build you a sample, but you should be able to set a custom base url for the API.
From the SDK documentation:
var customUri = new Uri("https://custom-api-url.com");
var boxConfig = new BoxConfigBuilder("clientID", "clientSecret")
.SetBoxApiHostUri(customUri)
.Build();
Let us know if this helps.
Cheers
Thanks for the reply!
I had to massage my code a little to use the BoxConfigBuilder vs my static call BoxConfig.CreateFromJsonString(tokendata) but I got it to compile. It works with both the base and the testing API URL, so I guess I’m good to go (at least on my development computer). I’ll need to check the SSL/TLS configuration on the production server just to be sure.
Thanks for the help!
randy
Awesome, feel free to continue to reach out to us!
Cheers
