I have created an app with a v2 webhook. The webhook triggers a JAVA application when it runs locally everything is good, but when the same application is being run inside a VM, the webhook is not getting triggered.
Can anyone help what could be the issue or where can I see the logs to find the problem?
Hello Sourav. Welcome to the community. I moved your post to the appropriate forum and @smartoneinok is taking a look, but wanted to let you know we’re on it.
Hi!
I’ve got a couple questions for you.
What cloud service are you using to run the VM in?
In order for Box to be call the application, the webhook url would need to be accessible by any public user. Is the VM setup for public access?
Thanks,
Alex
