Usage under review process
Our app is currently under review. Even though it is in the review process, is it okay for our customers to use it?
Are there any restrictions, such as a maximum number of connections?
Hi @hiroyukis
I don’t think it is possible, but let me check internally.
Best regards
@rbarbosa do you have any updates?
Hi @hiroyukis
The information I have is that yes they can use the app.
Best regards
