Where is box_sdk_gen.auth?
I’m excited about box_sdk_gen! I’m trying this , but “ModuleNotFoundError: No module named ‘box_sdk_gen.auth’” occured. of cource I’ve done pip install box_sdk_gen. where’s box_sdk_gen.auth?
Hi @tatsumi0040 , welcome to the forum!
This workshop is developed to work with the box sdk gen version 0.5.1 as specified in the requirements.txt included in the project.
When you do pip install box-sdk-gen, you are installing a newer version, for example as of today 0.6.1, and there are few changes.
We will eventually update this workshop to work with a newer version of the SDK.
In the mean time I recommend you work with a python virtual environment and follow the setup instructions in the README.md file in the root of the GitHub repository.
Not sure if you are using Windows, Linux or MacOS, but I want to call your attention specifically to this part of the README.md file:
Get the code
git clone git@github.com:barduinor/box-python-gen-workshop.git
cd box-python-gen-workshop
Set up your virtual environment
On MacOS and Linux (Python 3.12)
python3 -m venv .venv
source .venv/bin/activate
pip install --upgrade pip
pip install -r requirements.txt
Create your local application environment file
cp sample_oauth.env .oauth.env
Edit your .oauth.env file to include your client id and secret, and execute the test_oauth.py script to check if the authentication is working.
The key is the pip install -r requirements.txt which will install the specific versions for this workshop.
From this point you should be able to do almost all workshops available.
Sadly, the Box AI API and the Metadata AI extraction API have not yet been released to the public, and are in beta.
If you give me a bit more context on your company and use case, I may be able to convince the product manager and include your company in a private beta program, to turn on these features.
Let us know.
