JWT token not generated
Hi Team,
We are constantly getting below error when our automated jenkins jobs trying to upload files on box folder:
access_token = response.json()[‘access_token’]
KeyError: ‘access_token’
The same jobs are working fine on staging server with same configurations means files are being uploaded to box folders using the same app config on our staging server.
The issue we are facing is in production jenkins jobs, it was working fine till 24th dec but now continue to fails generating access token.
We are currently using JWT without SDK approach.
Looking forward for some help.
Thanks,
Shailendra J
Hi @shailendraj
Assuming you’re making a request to get an access token, and using the JWT in the authorization header, it seems you’re getting back an error.
What error is it? What message is coming back from the API?
Let us know.
Cheers
Hi @rbarbosa
We are getting below error:
:slight_smile:
Please send the actual response.json() content
The error you’re gettin is because ‘access_token’ is not present on the response. but what is the actual response?
